[postgis-devel] [PostGIS] #240: ST_SimplifyPreserveTopology documentation unclear on intersections within a MultiPolygon
PostGIS trac at osgeo.org
Mon Aug 17 04:45:48 PDT 2009
MultiPolygon
  Reporter:  perchrh  |       Owner:  robe
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  postgis 1.5.0
 Component:  postgis  |     Version:
Resolution:           |    Keywords:
Comment (by robe):
 Haven't given that much thought, but I always seem to end up with valid
 multipolygons at the end.  Kevin you know?  Maybe Martin,Paul, Sandro, or
 Mateusz can chime in. I see Sandro and Mateusz name in the GEOS log of
 porting that function simplify/TopologyPreservingSimplifier.
 I had always assumed it works with each polygon individually and does a
 check at the end to ensure the multipolygon is still valid.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/240#comment:1>
