[postgis-devel] [PostGIS] #241: ST_LineCrossingDirection Server Crash (Segfault)
trac at osgeo.org
Thu Aug 20 01:30:51 PDT 2009
Reporter: batzee | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: postgis 1.4.1
Component: postgis | Version: 1.4.X
Resolution: | Keywords: segfault
Comment (by nicklas):
I took a quick look at Reginas example. The crash only appears when there
is more than one row.
If I make a table like
create table c as
SELECT ST_MakeLine(ST_Point(-10,40),ST_Point(40,-10)) As the_geom ;
insert into c
SELECT ST_MakeLine(ST_Point(0,40),ST_Point(40,0)) As the_geom ;
then this crashes:
SELECT sum(ST_LineCrossingDirection(the_geom,
ST_GeomFromText('LINESTRING(1 2,3 4)'))) FROM c
it also crashes if I run:
ST_GeomFromText('LINESTRING(1 2,3 4)'))) FROM c limit 1;
But it will not crash if I run:
ST_GeomFromText('LINESTRING(1 2,3 4)'))) FROM (select * from c limit 1) d
I don't know enough to understand the internal difference between the two
last examples. As I understand it it doesn't wich one of the two rows I
put first in the last example so it isn't the lines in itself that crashes
the function, but something hangeing there from the last run of the
function.
/Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/241#comment:8>
