[postgis-devel] Small boo boo
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Aug 20 03:30:37 PDT 2009
Dave Page wrote:
>> Of course, the Win32 1.4.1 installer could detect this and do it
>> automatically. I'm definitely committed to not changing the SQL signatures
>> for a point release, but I'm not sure we have a choice with this, otherwise
>> the ability upgrade through point releases will just fail :(  Anyone else
>> think of a better plan?
> Well it won't change the SQL signature, just the implementation. And
> postgres shouldn't care about a new function appearing in a .so.
Actually thinking about this, fail is probably too strong a word - it's
just that it can be confusing for the user if postgis_full_version()
says they need an upgrade.
I think the solution will have to be along the lines of "If you have
upgraded from 1.4.0 to 1.4.1 and SELECT postgis_full_version() says you
need to upgrade scripts, run this .sql file" (although of course some
packagers could incorporate this automatically).
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
