[postgis-devel] Small boo boo
Paragon Corporation lr at pcorp.us
Fri Aug 21 11:14:46 PDT 2009
Correct - well still under consideration. I think its rare we make changes
to the sql file except when introducing new functions (which we aren't going
to do anymore in microversions) so I suspect it won't be that much of an
issue if we for simplicity make that requirement.
The only case I can think of where this becomes a big issue is if we start
introducing a lot of sql/plpgsql functions from user contributions and those
are constantly under maintenance.  Given that lots of people can do this, I
suspect that would take on a life of its own anyway and shouldn't be
packaged as part of PostGIS core.  Maybe we would do packages like R does.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of strk
Sent: Friday, August 21, 2009 11:24 AM
To: PostGIS Development Discussion
Cc: 'Dave Page'
Subject: Re: [postgis-devel] Small boo boo
On Thu, Aug 20, 2009 at 02:03:42PM -0400, Paragon Corporation wrote:
> Strk,
> As of PostGIS 1.4 -- the PostGIS steering committee decided that in a
> micro version we will no longer allow the addition of functions, nor
> the changing of interface of existing functions.  I suggesting on top
> of that -- no SQL file changes because that's really the point of all of
this.
So if a bug is found in the implementation of an SQL or PL/PGSQL function we
can't release a micro version upgrade ?
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
