[postgis-devel] problem with spatial_ref_sys.sql
Kevin Neufeld kneufeld at refractions.net
Thu Aug 27 10:29:24 PDT 2009
Scroll to the beginning of the log, before all the
ERROR:  current transaction is aborted, commands ignored until end of transaction block
What's reason the block is aborted?
-- Kevin
Zico wrote:
> Hi,
> I have been trying to configure "fixmystreet" in my Debian 5.0 machine.
> I am following the doc:
> https://www.socialtext.net/lukec/index.cgi?howto_set_up_fixmystreet_ca_developer_environment
> But, here, when i go for the command:
>  *sudo -u postgres psql -d fixmystreet -f
> /usr/share/postgresql-8.3-postgis/spatial_ref_sys.sql
> Then the error comes:
> */psql:/usr/share/postgresql-8.3-postgis/spatial_ref_sys.sql:12757:
> transaction block
> ROLLBACK
> psql:/usr/share/postgresql-8.3-postgis/spatial_ref_sys.sql:12759:
> ERROR:  relation "spatial_ref_sys" does not exist
> How can i get rid off this problem? I need to setup this server as early
> as possible. So need your help badly.
> Best,
> Zico
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
