[postgis-devel] Problem with ~/postgresql-8.3-postgis/lwpostgis.sql
Paragon Corporation lr at pcorp.us
Sat Aug 29 12:56:38 PDT 2009
Zico,
This is a user question, you should be asking on the PostGIS Users group.
Which version of PostGIS are you trying to install? 1.3 or 1.4
In 1.4 the new file is just called postgis.sql (no longer lwpostgis.sql)
It could be that you are running the 1.3 file  and have postgis-1.4 .so/.dll
loaded.
Check line 6460 of your lwpostgis.sql file to see what that line says.
Since  that is where it is breaking.
Hope that helps,
Regina
  _____
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Zico
Sent: Saturday, August 29, 2009 1:37 PM
To: PostGIS Development Discussion
Subject: [postgis-devel] Problem with ~/postgresql-8.3-postgis/lwpostgis.sql
I  hv been trying to run this command  : psql -U postgres -f
/usr/share/postgresql-8.3-postgis/lwpostgis.sql fixmystreet
But.. I am facing this error:
psql:/usr/share/postgresql-8.3-postgis/lwpostgis.sql:6460: ERROR:  current
transaction is aborted, commands ignored until end of transaction block
I cannot understand this error. Can you help me?
Best,
Zico
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090829/b8f8e25c/attachment.html>
