[postgis-devel] Distance Madness
Nicklas Avén nicklas.aven at jordogskog.no
Tue Dec 1 11:12:49 PST 2009
Yes, I think you are right that my mistake was to use malloc./Nicklas
2009-12-01 Paul Ramsey wrote:
Nick,
>You asked if maybe you did something naive and the answer is "possibly
>yes". For example, if you did your allocations using malloc() you got
>a much more expensive heap allocation than if you used palloc() (or
>lwalloc() in the context of a pgsql build).
>But anyhow, yes, knowing the number of edges before-hand, and knowing
>our tree building scheme, we could easily allocate the whole segment
>in one go at the start (~1.5 * npoints * sizeof(node)).
>For 2.0, I've been thinking about the way to make this stuff "real",
>and I'm pretty sure the answer is to stick an extra handle on
>POINTARRAY for holding these optional structures. Then, an
>lwgeom_index(LWGEOM *g) function would walk into an LWGEOM, ensure all
>the *bbox pointers are filled in, and build the trees on all the
>POINTARRAYs. Then the whole thing could be neatly cached, if
>necessary, etc.
>P.
>On Tue, Dec 1, 2009 at 10:16 AM, Nicklas Avén
> wrote:
>> aul
>> If it is as I suspect that the number of memory allocations is the most
>> costly part of this, wouldn't it be possible to allocate all of it once and
>> for all. If you allocate one list of nodes for each level, the whole
>> structure of the tree is given. You know where the children and parents is
>> related to the start of the "level lists" the only thing missing is the min
>> and max x any y for each level.
>> /Nicklas
>> 2009-12-01 Nicklas Avén wrote:
>> I think I see what you are doing
>> Had to take another look...
>> The comarasion part is the same as I used for subgeometries and as you say
>> (I saw the blog too) the natural ordering of the edges should make the tree
>> very effective.
>> But I think you have to cache the tree to beat my calculation :-)
>> That belive comes from some trying I did when writing the code, before I had
>> found the qsort function. Then I build a tree as described in that C-bible I
>> can't remember the name, just to get the measure-values ordered. I think it
>> was the number of memory-allocations that showed to be very expensive. I
>> might have done som elementary mistake but when I tried that tree with one
>> node per vertex on the largest polygon of Alaska (about 70000 vertexes) it
>> used almost 7 seconds just to build the tree and read it ordered. The whole
>> calculation for distance between the largest polygons in Alaska and Texas
>> now uses less than 100 ms. But it is quite likely that I had done som
>> mistake in my treebuilding.
>> (That calculation Alaska Texas is extremly fast because Texas has that sharp
>> edge aginst Alaska which is easy for my algoritm to catch.)
>> /Nicklas
>> wow, I think postgis will be hard to beat in the long run :-)
>> I'm not used to study those tree things, but it will be very interesting to
>> follow this and try to understand it.
>> Will it work on overlapping bboxes too?
>> One thing I think is nice about "my" way of doing it, is that there is no
>> indexes included. The gain is that it can be nested in subqueries and CTE's
>> without loosing the speed. But I haven't really understood when that problem
>> occur of not using the indexes.
>> I have been thinking some in 3D terms too, totally without knowledge about
>> reality. But it shouldn't be too impossible to do the same tricks in 3D and
>> calculating point to surface instead of point to segment. But that would
>> need a 3D type. I don't know how that use to be built, but I have imagined a
>> list of 3D points and a related list with pointidentifiers in groups of
>> three, defining triangels. Then it would be quite fast to do like my
>> distance trick on the points and finding the surfaces to calculate distances
>> to with some index on the pointidentifiers list...
>> /Nicklas
>>> > Niklas,
>>> > >Your cunning sorting trick got into my head and I thought and thought
>>> > >on it and ended up borrowing the magic tree idea from Mark's prepared
>>> > >p-i-p code, and added another dimension to that, so the trees are
>>> > >actually in 2d space, and then starting thinking about how, given two
>>> > >of these trees you could quickly find things like intersections or
>>> > >even (*gasp*) distances...
>>> > >geog=# select distance(buffer('POINT(3 3)', 2),buffer('POINT(0 0)',
>>> > > 2));
>>> > > distance
>>> > > 0.242640687119285
>>> > >(1 row)
>>> > >geog=# select npoints(buffer('POINT(3 3)', 2));
>>> > > npoints
>>> > > 33
>>> > >(1 row)
>>> > >geog=# select 33*33;
>>> > > ?column?
>>> > > 1089
>>> > >(1 row)
>>> > >These two circles have 33 points each, so the brute force method
>>> > >requires 1089 distance calculations to come up with an answer. The
>>> > >magic trees took 29. It's also possible to *cache* the trees and
>>> > >re-use them, both for distance calculations and intersections and
>>> > >containments.
>>> > >Very exciting stuffs!
>>> > >However, we're almost to 1.5 and adding all the features you already
>>> > >have in your code (maximums, points and lines of shortness, etc) would
>>> > >take way too long. And I'm not sure my code is actually faster. Just
>>> > >that it's much faster than the brute force ways.
>>> > >It's all in lwtree.c in liblwgeom if you want to look.
>>> > >P.
>>> > >_______________________________________________
>>> > >postgis-devel mailing list
>>> > >postgis-devel at postgis.refractions.net
>>> > >postgis.refractions.net/mailman/listinfo/postgis-devel
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091201/faab93d7/attachment.html>
