[postgis-devel] [PostGIS] #333: VACUUM in spatial_ref_sys.sql throws error
PostGIS trac at osgeo.org
Thu Dec 3 12:13:41 PST 2009
  Reporter:  kneufeld  |       Owner:  pramsey
      Type:  defect    |      Status:  new
  Priority:  medium    |   Milestone:  PostGIS 1.5.0
 Component:  postgis   |     Version:  trunk
Resolution:            |    Keywords:
Comment (by kneufeld):
 Also, is there a reason the file is broken into two transaction blocks?
 When loading in PgAdmin, the first transaction succeeds, but then the
 VACUUM breaks the script.  The data is partly loaded.  I can't rerun the
 script, I have to truncate the table first, then attempt a reload.
 This kinda defeats the purpose of having a single transaction block, no?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/333#comment:1>
