[postgis-devel] [PostGIS] #160: prefix not recognized in 1.4.0SVN
PostGIS trac at osgeo.org
Fri Dec 4 08:30:57 PST 2009
  Reporter:  kneufeld  |       Owner:  mcayland
      Type:  defect    |      Status:  closed
  Priority:  low       |   Milestone:  PostGIS 1.4.0
 Component:  postgis   |     Version:
Resolution:  wontfix   |    Keywords:
Comment (by kneufeld):
 Hi Mark,
 You mentioned that PGXS understands DESTDIR and this apparently works:
 ./configure make DESTDIR=/path/to/somewhere install
 If so, is it possible to alter configure so that the first thing it does
 is take any specified --prefix value and assign it to DESTDIR?  Then
 --prefix would work again as before, no?
 -- Kevin
Ticket URL: <http://trac.osgeo.org/postgis/ticket/160#comment:9>
