[postgis-devel] [PostGIS] #340: [wktraster] Implement ST_AsJPEG function for raster
PostGIS trac at osgeo.org
Fri Dec 11 10:28:25 PST 2009
  Reporter:  mloskot    |       Owner:  mloskot
      Type:  task       |      Status:  assigned
  Priority:  medium     |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Old description:
> This tasks belongs to the Objective 0.1.6f specified in the
> [wiki:WKTRaster WKT Raster]
> [wiki:WKTRaster/PlanningAndFunding roadmap]
> As stated at the end of the comment 5 of the "Specification Comments
> following the Code Sprint" section of the working specifications, this
> function should be a PL/pgSQL wrapper around a more general
> ST_AsImage(format, params) function using GDAL to convert any raster to
> an image.
> The function should return a bytea.
> This function is particularly sensible to the number of band present in
> the raster as it normally needs 3 band (r,g,b).
> It is also very sensible to the pixel type of the raster since JPEG
> supports only values in the 0-255 range.
> See the working specifications for more details/questions.
> Priority should be given to these variants:
> ST_AsJPEG(raster, integer)
> ST_AsJPEG(raster, integer, integer, integer, integer)
> ST_AsJPEG(raster, integer, "GRAYSCALE", integer, min, max, text)
New description:
 ST_AsImage(format, params) function using GDAL to convert any raster to an
 image.
 ST_AsJPEG(raster, integer)[[BR]]
 ST_AsJPEG(raster, integer, integer, integer, integer)[[BR]]
 ST_AsJPEG(raster, integer, "GRAYSCALE", integer, min, max, text)[[BR]]
Ticket URL: <http://trac.osgeo.org/postgis/ticket/340#comment:4>
