[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
PostGIS trac at osgeo.org
Fri Dec 11 11:36:36 PST 2009
  Reporter:  robe     |       Owner:  colivier
      Type:  defect   |      Status:  new
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by pramsey):
 Under VCC perhaps we could use the pre-compiiled libxml2 binaries?
 Incidentally, I switched to libxml2 2.6.32 and things "worked" but I think
 that's because I ended up with a static compile instead of a dynamic one?
 How did you tell?
 (Update, maybe not, depends.exe reports my postgis dll still depends on
 libxml2-2.dll.)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:41>
