[postgis-devel] [PostGIS] #348: [wktraster] st_raster_envelope & st_raster_to_box2d return different results
PostGIS trac at osgeo.org
Wed Dec 16 08:47:38 PST 2009
results
  Reporter:  pracine    |       Owner:  pracine
      Type:  defect     |      Status:  assigned
  Priority:  high       |   Milestone:  WKTRaster 0.1.6
 Component:  wktraster  |     Version:  trunk
Resolution:             |    Keywords:
Old description:
> SELECT ST_AsText(st_raster_envelope(rast)) FROM mytable
> UNION ALL
> SELECT ST_AsText(st_raster_to_box2d(rast)) FROM mytable
> should return two identical lines
New description:
 SELECT ST_AsText(st_raster_envelope(rast)) FROM mytable[[BR]]
 UNION ALL[[BR]]
 should return two identical lines.
Comment (by pracine):
 Reformated the query to make the two lines evident.
 This bug appears when the coordinates of the center upper left pixel are
 very precises i.e. -85.750000033333492
 A first problem is that the order is different.
 A second problem is that the numbers are also different when the precision
 is high. I guess this problem is related to the fact that bbox are stored
 as float4s in PostGIS and our version of ST_Envelope returns the float8s
 version. I think we should return the float4s bbox. I have to test further
 though.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/348#comment:3>
