[postgis-devel] 1.4.1 Bundled
Devrim GÜNDÜZ devrim at gunduz.org
Wed Dec 16 23:18:35 PST 2009
On Wed, 2009-12-16 at 22:12 -0800, Paul Ramsey wrote:
> OK, there is a downloadable tarball at
> http://postgis.org/download/postgis-1.4.1.tar.gz
> Check it, test it, love it.
I loved it, but I'm having failure compiling it under Fedora 11. Related
build log is attached. It is related to java stuff. Please note that
this was working as of 1.4.0.
Regards,
Devrim GÜNDÜZ, RHCE
Command Prompt - http://www.CommandPrompt.com
devrim~gunduz.org, devrim~PostgreSQL.org, devrim.gunduz~linux.org.tr
http://www.gunduz.org  Twitter: http://twitter.com/devrimgunduz
Buildfile: build.xml
 [property] java.io.IOException: Cannot run program "/bin/env": java.io.IOException: error=12, Cannot allocate memory
 [property] 	at java.lang.ProcessBuilder.start(ProcessBuilder.java:474)
 [property] 	at java.lang.Runtime.exec(Runtime.java:610)
 [property] 	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
 [property] 	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
 [property] 	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
 [property] 	at java.lang.reflect.Method.invoke(Method.java:616)
 [property] 	at org.apache.tools.ant.taskdefs.Execute$Java13CommandLauncher.exec(Execute.java:832)
 [property] 	at org.apache.tools.ant.taskdefs.Execute.launch(Execute.java:447)
 [property] 	at org.apache.tools.ant.taskdefs.Execute.execute(Execute.java:461)
 [property] 	at org.apache.tools.ant.taskdefs.Execute.getProcEnvironment(Execute.java:167)
 [property] 	at org.apache.tools.ant.taskdefs.Property.loadEnvironment(Property.java:527)
 [property] 	at org.apache.tools.ant.taskdefs.Property.execute(Property.java:403)
 [property] 	at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:288)
 [property] 	at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
 [property] 	at org.apache.tools.ant.Task.perform(Task.java:348)
 [property] 	at org.apache.tools.ant.Target.execute(Target.java:357)
 [property] 	at org.apache.tools.ant.helper.ProjectHelper2.parse(ProjectHelper2.java:142)
 [property] 	at org.apache.tools.ant.ProjectHelper.configureProject(ProjectHelper.java:93)
 [property] 	at org.apache.tools.ant.Main.runBuild(Main.java:743)
 [property] 	at org.apache.tools.ant.Main.startAnt(Main.java:217)
 [property] 	at org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
 [property] 	at org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
 [property] Caused by: java.io.IOException: java.io.IOException: error=12, Cannot allocate memory
 [property] 	at java.lang.UNIXProcess.<init>(UNIXProcess.java:164)
 [property] 	at java.lang.ProcessImpl.start(ProcessImpl.java:81)
 [property] 	at java.lang.ProcessBuilder.start(ProcessBuilder.java:467)
 [property] 	... 25 more
stubbuild:
    [mkdir] Created dir: /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/stubbin
    [javac] Compiling 2 source files to /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/stubbin
standard-compile:
    [mkdir] Created dir: /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/bin
    [javac] Compiling 36 source files to /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/bin
standard-jar:
     [copy] Copying 1 file to /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/bin/org/postgresql
     [copy] Copying 1 file to /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/bin/org/postgis
      [jar] Building jar: /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/postgis-1.4.1.jar
      [jar] Building jar: /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/postgis_debug-1.4.1.jar
      [jar] org/postgresql/driverconfig.properties already added, skipping
build-standard:
     [echo] Building standard JDBC jar
boxtestoffline-regression:
     [java] /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/build.xml:140: java.io.IOException: Cannot run program "/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0/jre/bin/java": java.io.IOException: error=12,
     [java] 	at org.apache.tools.ant.taskdefs.Java.fork(Java.java:791)
     [java] 	at org.apache.tools.ant.taskdefs.Java.executeJava(Java.java:211)
     [java] 	at org.apache.tools.ant.taskdefs.Java.executeJava(Java.java:132)
     [java] 	at org.apache.tools.ant.taskdefs.Java.execute(Java.java:105)
     [java] 	at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:288)
     [java] 	at sun.reflect.GeneratedMethodAccessor1.invoke(Unknown Source)
     [java] 	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
     [java] 	at java.lang.reflect.Method.invoke(Method.java:616)
     [java] 	at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
     [java] 	at org.apache.tools.ant.Task.perform(Task.java:348)
     [java] 	at org.apache.tools.ant.Target.execute(Target.java:357)
     [java] 	at org.apache.tools.ant.Target.performTasks(Target.java:385)
     [java] 	at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1337)
     [java] 	at org.apache.tools.ant.Project.executeTarget(Project.java:1306)
     [java] 	at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
     [java] 	at org.apache.tools.ant.Project.executeTargets(Project.java:1189)
     [java] 	at org.apache.tools.ant.Main.runBuild(Main.java:758)
     [java] 	at org.apache.tools.ant.Main.startAnt(Main.java:217)
     [java] 	at org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
     [java] 	at org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
     [java] Caused by: java.io.IOException: Cannot run program "/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0/jre/bin/java": java.io.IOException: error=12, Cannot allocate memory
     [java] 	at java.lang.ProcessBuilder.start(ProcessBuilder.java:474)
     [java] 	at java.lang.Runtime.exec(Runtime.java:610)
     [java] 	at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
     [java] 	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
     [java] 	at org.apache.tools.ant.taskdefs.Execute$Java13CommandLauncher.exec(Execute.java:832)
     [java] 	at org.apache.tools.ant.taskdefs.Execute.launch(Execute.java:447)
     [java] 	at org.apache.tools.ant.taskdefs.Execute.execute(Execute.java:461)
     [java] 	at org.apache.tools.ant.taskdefs.Java.fork(Java.java:784)
     [java] 	... 19 more
     [java] Caused by: java.io.IOException: java.io.IOException: error=12, Cannot allocate memory
     [java] 	at java.lang.UNIXProcess.<init>(UNIXProcess.java:164)
     [java] 	at java.lang.ProcessImpl.start(ProcessImpl.java:81)
     [java] 	at java.lang.ProcessBuilder.start(ProcessBuilder.java:467)
     [java] 	... 28 more
     [java] --- Nested Exception ---
     [java] java.io.IOException: Cannot run program "/usr/lib/jvm/java-1.6.0-openjdk-1.6.0.0/jre/bin/java": java.io.IOException: error=12, Cannot allocate memory
     [java] 	... 28 more
     [java] Java Result: -1
BUILD FAILED
/home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/build.xml:146: /home/devrim/rpm/BUILD/postgis-1.4.1/java/jdbc/test.log.err doesn't exist
Total time: 14 seconds
error: Bad exit status from /var/tmp/rpm-tmp.HUIP9K (%build)
Desc: This is a digitally signed message part
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20091217/463a8444/attachment.sig>
