[postgis-devel] 1.4.1 Bundled
Havard Tveite havard.tveite at umb.no
Thu Dec 17 00:55:21 PST 2009
All fine, but make check gave 3 (harmless) failures.
Extracts from the diffs:
test_13_out
! HINT:  "POLYGON( (0 0, 10 0, 10 10, 0 10)" <-- parse error at position 33 within geometry
! HINT:  "POLYGON( (0 0, 10 0, 10 10, 0 10) )" <-- parse error at position 35 within geometry
test_30_out:
! HINT:  "...44.84399355252685 -30.76123924022086)" <-- parse error at position 646 within geometry
! HINT:  "...4.84399355252685 -30.76123924022086))" <-- parse error at position 647 within geometry
! HINT:  "..., 1 4, 0 0)), (1.7 1, 1.4 0.4, 1.7 1)" <-- parse error at position 112 within geometry
! HINT:  "...1 4, 0 0)), (1.7 1, 1.4 0.4, 1.7 1) )" <-- parse error at position 114 within geometry
test_38_diff:
! HINT:  "POLYGON((0 0, 1 1, 0 0)" <-- parse error at position 23 within geometry
! HINT:  "POLYGON((0 0, 1 1, 0 0))" <-- parse error at position 24 within geometry
(Ubuntu Etch 64 bit, gcc 4.1.2.)
Håvard Tveite
PS  In order to run make check before make install I had to
modify postgis.sql in regress to use the new 1.4.1 postgis
library.
Paul Ramsey wrote:
> OK, there is a downloadable tarball at
> http://postgis.org/download/postgis-1.4.1.tar.gz
> Check it, test it, love it. Kevin, if nobody has howled by the time
> you get into work tomorrow morning, put the download link public and
> post a news item, OK?
> Thanks folks!
> Paul
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
Håvard Tveite
Department of Mathematical Sciences and Technology, UMB
Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.umb.no/imt/
