[postgis-devel] [PostGIS] #204: Merge shp2pgsql/shp2pgsql-core into one entity
PostGIS trac at osgeo.org
Thu Dec 17 04:56:47 PST 2009
  Reporter:  mcayland  |       Owner:  mcayland
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 1.5.0
 Component:  postgis   |     Version:  trunk
Resolution:  fixed     |    Keywords:
Changes (by mcayland):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Okay. I believe my work here is done. Please test and let me know if you
 find anything.
 The only thing to note is that the loader still defaults to using INSERT
 syntax; to change the default for both the command line and GUI, simply
 change set_config_defaults(). Otherwise we can force it for just the GUI
 when shp2pgsql-gui starts.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/204#comment:5>
