[postgis-devel] [PostGIS] #344: Libxml2 become mandatory
PostGIS trac at osgeo.org
Fri Dec 18 11:22:36 PST 2009
  Reporter:  colivier  |       Owner:  colivier
      Type:  task      |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 1.5.0
 Component:  postgis   |     Version:
Resolution:  fixed     |    Keywords:
Comment (by colivier):
 FYI, as a commit side effect, Hudson is right now broken, with following:
 configure: error: could not find xml2-config from libxml2 within the
 current path. You may need to try re-running configure with a --with-
 xml2config parameter.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/344#comment:2>
