[postgis-devel] getopt.h
Paul Ramsey pramsey at opengeo.org
Mon Dec 21 08:04:34 PST 2009
I tested solaris after switching to system getopt, and it worked fine,
so who knows, the original issue has vanished in the sands of time.
P
On Mon, Dec 21, 2009 at 6:44 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul Ramsey wrote:
>> Don't want to get into a reversion war here... I want to remove the
>> getopt custom junk in loader. I know I broke MinGW, but the solution
>> isn't to add pgis_getopt back in, it's to find a system getopt for
>> MinGW, and it turns out there is one, you just have to test for
>> HAVE_UNISTD and if it isn't there, include <getopt.h> and minGW works
>> fine.
>> The old getopt stuff dates back to almost the beginning of PostGIS,
>> when Dave dumped it in there rather than figure out an incompatibility
>> between the Solaris getopt and the linux getopt. So when I ripped it
>> out, I tested on Solaris and everything worked fine.
>> P.
> If we don't care about broken Solaris anymore, I think the correct way to do
> this would be to create a directory full of functions that may not be
> available on every platform, and then use autoconf's AC_LIBOBJ and friends
> so that all the magic happens behind the scenes.
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> Sirius Labs: http://www.siriusit.co.uk/labs
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
