[postgis-devel] Issue 104 in postgis: shp2pgsql is using deprecated PostgreSQL escape syntax
codesite-noreply at google.com codesite-noreply at google.com
Mon Feb 2 15:02:59 PST 2009
Comment #1 on issue 104 by pwramsey3: shp2pgsql is using deprecated
http://code.google.com/p/postgis/issues/detail?id=104
Try this micro-patch and see if it goes away...
	esc.patch  780 bytes
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
