[postgis-devel] Issue 59 in postgis: pg_detoast_datum_slice handle points
codesite-noreply at google.com codesite-noreply at google.com
Mon Feb 2 16:24:42 PST 2009
Updates:
	Status: WontFix
Comment #1 on issue 59 by pwramsey3: pg_detoast_datum_slice handle points
http://code.google.com/p/postgis/issues/detail?id=59
I tested this change and it didn't make any measurable difference, so I'm
closing this.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
