[postgis-devel] Issue 112 in postgis: ST_CurveToLine sometimes crashes server
codesite-noreply at google.com codesite-noreply at google.com
Tue Feb 3 09:55:34 PST 2009
Comment #1 on issue 112 by mark.cav... at siriusit.co.uk: ST_CurveToLine
http://code.google.com/p/postgis/issues/detail?id=112
Here's the preliminary backtrace:
(gdb) bt
#0  0x000000000067c68a in pfree ()
#1  0x00007ffa773e502b in lwgeom_release (lwgeom=0xb7f420) at lwgeom.c:332
#2  0x00007ffa773df079 in LWGEOM_curve_segmentize () from
/home/pg83/rel-8.3.5/lib/postgresql/postgis-1.4.so
#3  0x00000000005294bd in ExecMakeFunctionResult ()
#4  0x0000000000527615 in ExecEvalFuncArgs ()
#5  0x0000000000529433 in ExecMakeFunctionResult ()
#6  0x00000000005273ce in ExecProject ()
#7  0x000000000052d1df in ExecScan ()
#8  0x00000000005268e8 in ExecProcNode ()
#9  0x0000000000524905 in ExecutorRun ()
#10 0x00000000005be5a0 in PortalRunSelect ()
#11 0x00000000005bfc09 in PortalRun ()
#12 0x00000000005baeac in exec_simple_query ()
#13 0x00000000005bc3d7 in PostgresMain ()
#14 0x00000000005907b2 in ServerLoop ()
#15 0x0000000000591494 in PostmasterMain ()
#16 0x0000000000546b48 in main ()
(gdb) frame 1
332                     lwfree(lwgeom->bbox);
Current language:  auto; currently c
(gdb)
I suspect it's probably related to some geometries having bboxs and some
not...
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
