[postgis-devel] Issue 109 in postgis: Some operators not supported for Circular
codesite-noreply at google.com codesite-noreply at google.com
Tue Feb 3 10:00:37 PST 2009
Comment #2 on issue 109 by mark.cav... at siriusit.co.uk: Some operators not
http://code.google.com/p/postgis/issues/detail?id=109
Yeah, I've already swapped over quite a few messages to report the geometry
type
rather than just the number. I would say we should just do this here, since
nobody
has complained about it before.
I don't see the fact that we are not 100% feature-complete as being a bug.
As long as
we don't crash the backend and display a useful message then we should be
fine.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
