[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
codesite-noreply at google.com codesite-noreply at google.com
Wed Feb 4 09:48:11 PST 2009
Comment #10 on issue 95 by ke... at refractions.net: PostGIS 1.4 documentation
update
http://code.google.com/p/postgis/issues/detail?id=95
Ah.. of course it's all about selectivity.  If overleft represents a
significant
portion of a table,  it obviously won't use the index ... K.  I'll have to
change the
Note.
-- Kevin
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
