[postgis-devel] Issue 76 in postgis: ST_DumpPoints - I think we said we would add to TODO
codesite-noreply at google.com codesite-noreply at google.com
Thu Feb 5 17:34:35 PST 2009
Updates:
	Status: Accepted
	Labels: -Priority-Low Priority-Medium
Comment #2 on issue 76 by robe.... at cityofboston.gov: ST_DumpPoints - I
http://code.google.com/p/postgis/issues/detail?id=76
I always thought so.  You would definitely need to group points back with
the
specific Polygon/Line they came from and that is why the path is probably
even more
so important for ST_DumpPoints
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
