[postgis-devel] Issue 114 in postgis: Could not find base type for aggregate accum when using postgis_restore.pl
codesite-noreply at google.com codesite-noreply at google.com
Fri Feb 6 13:17:54 PST 2009
Status: New
Owner: ----
New issue 114 by hobu.inc: Could not find base type for aggregate accum
http://code.google.com/p/postgis/issues/detail?id=114
When attempting to load an 8.3 database that was dumped -Fc and use the
postgis_restore.pl utility, it halts with the following error:
(CREATE AGGREGATE accum ()
Attempting to make the database and postgis-enable it beforehand also fails.
This error is with PostGIS trunk and Postgresql trunk as of today.
Thanks,
Howard
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
