[postgis-devel] Issue 114 in postgis: Could not find base type for aggregate accum when using postgis_restore.pl
codesite-noreply at google.com codesite-noreply at google.com
Mon Feb 9 14:53:04 PST 2009
Updates:
	Status: Testing
Comment #2 on issue 114 by pwramsey3: Could not find base type for
http://code.google.com/p/postgis/issues/detail?id=114
Should be fixed at r3675.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
