[postgis-devel] Issue 94 in postgis: Rename folders/files to be more consistent
codesite-noreply at google.com codesite-noreply at google.com
Tue Feb 10 13:04:15 PST 2009
Comment #6 on issue 94 by pwramsey3: Rename folders/files to be more
consistent
http://code.google.com/p/postgis/issues/detail?id=94
I can do the ./lwgeom/ rename if you wish, Mark.
P
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
