[postgis-devel] Issue 94 in postgis: Rename folders/files to be more consistent
codesite-noreply at google.com codesite-noreply at google.com
Wed Feb 11 09:35:38 PST 2009
Comment #8 on issue 94 by pwramsey3: Rename folders/files to be more
consistent
http://code.google.com/p/postgis/issues/detail?id=94
Done. Note that if you're using TortoiseSVN, you'll need to uncheck "Stop
on copy/rename" in the log display
options, or the revisions will appear to have been lost.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
