[postgis-devel] Compiling under Windows
Obe, Regina robe.dnd at cityofboston.gov
Thu Feb 12 05:10:38 PST 2009
Mark,
Actually I'm not quite sure what to make of this.  Normally what I do is
do a make, but my PostgreSQL install is elsewhere, so I just copy the
dlls from the postgis folder.
It seems though that if I do a
make and then a
make install
, the dlls in the installed directory are magically renamed without the
lib extension so they have the right names.  Just not the right names in
the postgis folder.
This doesn't happen in my OpenSUSE install. The so files in the postgis
folder do not have a lib in front of them.
Signed,
Very confused Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Mark
Cave-Ayland
Sent: Thursday, February 12, 2009 7:57 AM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Compiling under Windows
Obe, Regina wrote:
> I thought this was just because I hadn't updated my subversion, but I
> still have this problem.  I haven't blown out my subversion folder to
> verify though.
> Under windows, the dll has the wrong name.  It comes out as
> libpostgis-1.4.dll and to install it, I have to rename it to
> postgis-1.4.dll
> Is this just me or are others having this problem?
> Thanks,
> Regina
Hmm that's strange - the names are automatically generated by PGXS and
as long as everything is called the same thing, it should just work. How
does it compare with modules from contrib which also use PGXS? Do these
have a lib* prefix on Win32 aswell? (Apologies but I don't have access
to my Win32 VM at the moment)
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
