[postgis-devel] Issue 116 in postgis: Hex string representing POLYGON EMPTY crashes postmaster
codesite-noreply at google.com codesite-noreply at google.com
Thu Feb 19 01:42:47 PST 2009
Comment #2 on issue 116 by mark.cav... at siriusit.co.uk: Hex string
http://code.google.com/p/postgis/issues/detail?id=116
Confirmed here too - also crashes on trunk.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
