[postgis-devel] Making postgis_comments.sql
Obe, Regina robe.dnd at cityofboston.gov
Thu Feb 19 01:48:39 PST 2009
I tried to change the Makefile.in in docs/ to autogenerate the postgis_comments.sql, but don't seem to be having much luck.
Can some make wizard tell me what I am doing wrong.
I created as section postgis_comments.sql to define the compile
and in the all: call that.
Also wondering where this file should sit.  I guess ideally it should sit at the root with spatial_ref_sys.sql as it does in the 1.3.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090219/1cf67be8/attachment.html>
