[postgis-devel] Issue 105 in postgis: pgsql2shp seems to produce incorrect dbase files, problems importing into Gnumeric
codesite-noreply at google.com codesite-noreply at google.com
Thu Feb 19 12:01:02 PST 2009
Updates:
	Status: Testing
Comment #1 on issue 105 by pwramsey3: pgsql2shp seems to produce incorrect
http://code.google.com/p/postgis/issues/detail?id=105
Should be fixed in 1.3 and trunk at r3749.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
