[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Sat Feb 21 04:50:05 PST 2009
Status: New
Owner: ----
New issue 119 by mgl.gis: ST_AsSVG crashed DB backend with large geometries.
http://code.google.com/p/postgis/issues/detail?id=119
Hello, this is a follow-up from a question I posted on the users list.
I've found that ST_AsSVG will cause the database connection to lock-up,
with the following message in the pg_log:
** glibc detected *** postgres: postgres testdb [local] SELECT: >
realloc(): invalid next size: 0x000000000220f410 ***
I've attached a sample geometry in WKT/WKB format, but the geometry itself
seems to be arbitrary, as I can cause this to happen with a variety of
geometries that I merge together using st_union.  The attached sample is
just a bunch of lines and points that I selected from a couple layers I
have.
If there is anything I can do to help debug this, let me know.
	biggeom_ewkb.txt  297 KB
	biggeom_ewkt.txt  312 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
