[postgis-devel] Making postgis_comments.sql
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Feb 23 05:38:44 PST 2009
Obe, Regina wrote:
> Then how come when I download the svn build from the site, I don't see
> it in there?  Is there something wrong with the hudson build that its
> not doing a re-run of configure maybe?
I suspect you'll find that the Hudson build runs the pdf target directly
rather than the all target - but you'll need to check the logs.
> Okay will give this a try.  I assume this has to be the name of the
> action as well or does it just have to be the actual action like.  so I
> would change to
> all: html/postgis.html	../postgis_comments.sql
> ../postgis_comments.sql: ./xsl/postgis_comments.sql.xsl
> reference_new.xml
> 	$(XSLTPROC) ./xsl/postgis_comments.sql.xsl reference_new.xml >
Yup, that's it - you'll need to change both.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
