[postgis-devel] More dump comments
Obe, Regina robe.dnd at cityofboston.gov
Fri Feb 27 10:26:42 PST 2009
I'm wondering if its because its got a , in there.  Though I would think the
{} would be sufficient.  Could be just a display artifact in psql I suppose.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Mark Cave-Ayland
Sent: Fri 2/27/2009 12:33 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] More dump comments
Obe, Regina wrote:
> Mark or Tom,
> Okay I did this for 1.4 but have not done it for 1.3 yet.  We don't
> support 8.0 in 1.3 either correct.
Since 1.3 is in bug-fix only mode, and it's not critical, I wouldn't
back-patch it at all.
> In inspecting the torture test, I noticed something strange with the
> dump results that I don't think have anything to do with my changes.
> though I'll have to revert back to be sure.
> When dumping geometry collections -- it dumps out like this
>                      ?column?
>  ST_Dump GCSet3D: Start Testing GEOMETRYCOLLECTION
> (1 row)
> BEGIN
> st_dump
> ("{1,1}",01010000A0E610000000000000000024C000000000000049400000000000000
> 040)
> But for MULTIPOLYGONs and single geom constructs, we don't have double
> quotes.  Why do we have quotes here.  Is that even legal? (or is that
> part of what Bless does)
> Below is a sample of a multi
>                       ?column?
>  ST_Dump MultiLineSet: Start Testing MULTILINESTRING
> (1 row)
> BEGIN
>                                               st_dump
> ({1},0102000020E61000000200000000000000000024C00000000000004440000000000
> 000444000000000000024C0)
Hmmm. Not sure at the moment without digging into the code...
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090227/ede1b309/attachment.html>
