[postgis-devel] More dump comments
Obe, Regina robe.dnd at cityofboston.gov
Fri Feb 27 10:37:42 PST 2009
Mark,
>> Hmmm. Not sure at the moment without digging into the code...
> I'm wondering if its because its got a , in there.  Though I would think the
> {} would be sufficient.  Could be just a display artifact in psql I suppose.
I verified it does the same in old installs and if you do
SELECT (ST_Dump(foo.the_geom))
FROM (SELECT ST_Collect(ST_Multi(the_geom)) as the_geom
fROM sometable) as foo
It does the same "{1,2}" so its not a new thing
I also checked
SELECT (ST_Dump(foo.the_geom)).path
or
SELECT (ST_Dump(foo.the_geom)).path[1]
fROM sometable) as foo;
and those look as I would expect (no quotes).  So I guess its some sort of artifact of the
displaying of a geometry_dump with , in the path that doesn't seem to affect
its functionality
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090227/98caf330/attachment.html>
