[postgis-devel] Issue 91 in postgis: "makefile check" Shows check failed of sql-mm-circularstring in PostGIS
codesite-noreply at google.com codesite-noreply at google.com
Sun Jan 4 10:38:54 PST 2009
Comment #1 on issue 91 by mark.cav... at siriusit.co.uk: "makefile check"
http://code.google.com/p/postgis/issues/detail?id=91
It all seems to work fine here so we need some more information - supplying
the test
diffs in a .tar.gz file would be helpful here.
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
