[postgis-devel] GUI Time
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Mon Jan 5 02:18:19 PST 2009
Paul Ramsey wrote:
> Hi folks,
> My Christmas present to myself was trying to do a GUI for shape
> importing (and eventually exporting). It turned out the GUI wasn't too
> hard... unfortunately when it came time to bolt in the actual guts, the
> crufty legacy code got in the way... the assumption of emitting to
> stdout is pretty backed in. So getting this working is going to take a
> pretty radical re-work. I'll work off to the side of the existing code,
> and create three new bits:
> shp2pgsql-core.c  - where the work gets done
> shp2pgsql-gui.c  - the gui frontend
> shp2pgsql-cli.c  - the commandline frontend
> Best,
> P.
Yup indeed. I did some testing on liblwgeom over Christmas (see email to
follow over the next few days) and realised that the existing dual
memory model is just plain bad.
My feeling is that we need to get liblwgeom to the point where we can
rip out the lwgeom_init_allocators() callback and handle the memory
management/errors ourselves, so this would be one less thing for you to
worry about.
But yeah, the loaders aren't the best example of C coding around and so
I wouldn't be averse to them being reworked. Perhaps similar to
liblwgeom you could make shp2pgsql-core.c a static library which gets
linked into both the CLI and GUI versions? I'd suggest if this is major
work then it should go into a separate branch so that trunk will work as
is, and then import the code into trunk when you have something tested
that works.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
