[postgis-devel] Issue 90 in postgis: AddGeometryColumn inappropriately defaults to current_schema() if given nonexistent schema
codesite-noreply at google.com codesite-noreply at google.com
Tue Jan 6 12:53:29 PST 2009
Comment #2 on issue 90 by reid at reidster.net: AddGeometryColumn
http://code.google.com/p/postgis/issues/detail?id=90
> This is because this function is a wrapper for
AddGeometryColumn(table_name,
> column_name, srid, type, dimension), where the schemaname is obtained
from the
> search path.  You'd prefer that this is not the case?  The alternative
would be
> duplicate the code to the schema-qualified variant and simply error on an
> incorrect schemaname. If others are with you on this behaviour, it's
certainly
> possible to change this.
Actually (in 1.3.3 at least), it seems that both
AddGeometryColumn(table_name, ...)
and AddGeometryColumn(schema_name, ...) are wrappers for a third variant,
AddGeometryColumn(catalog_name, schema_name, table_name, ...).
As for a fix: can the RAISE NOTICE on line 2840 of lwpostgis.sql be
replaced with
RAISE EXCEPTION and line 2841 deleted?
> As for the CONTEXT messages: whenever you raise a notice or error in
plpgsql, a
> context message is also displayed.  Unless someone knows how to separate
this
> verbose debugging information from a regular notice or error message,
this is the
> best we can do at the moment with plpgsql.
That's a minor problem. I wouldn't be too sad if the CONTEXT remained.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
