[postgis-devel] Issue 92 in postgis: Error in Estimated_Extent() when used with point geometry
codesite-noreply at google.com codesite-noreply at google.com
Wed Jan 7 04:38:13 PST 2009
Comment #2 on issue 92 by aroranidh: Error in Estimated_Extent() when used
with point geometry
http://code.google.com/p/postgis/issues/detail?id=92
Thnx Mark,
It works after analyze command
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
