[postgis-devel] Compile trouble of Trunk on MingW
Obe, Regina robe.dnd at cityofboston.gov
Wed Jan 7 06:34:06 PST 2009
I'm still having trouble compiling 1.4 SVN under MingW.  It keeps
complaining that it can't find my Proj install.  My install looks fine
as far as I can tell.  The proj.exe etc gets installed.  I verified my
Proj 4.6.1 proj_api.h is in C:\msys\1.0\local\include\proj_api.h
I tried this
./configure --libdir=/usr/local/lib --includedir=/usr/local/include
--with-pgconfig=/usr/local/pgsql/bin/pg_config
--with-projdir=/usr/local/include
and keep getting the error
configure: error: could not find proj_api.h - you may need to specify
the directory of a PROJ.4 installation using --with-projdir
I tried using both SVN and nightly snapshot with same error.  Have no
clue what I am missing here.
GEOS seems to be automatically detected and pgconfig seem to work fine
with the --with-pgconfig.
Any thoughts would be appreciated.
Thanks,
Regina
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
