[postgis-devel] Issue 90 in postgis: AddGeometryColumn inappropriately defaults to current_schema() if given nonexistent schema
codesite-noreply at google.com codesite-noreply at google.com
Wed Jan 7 10:14:20 PST 2009
Comment #7 on issue 90 by reid at reidster.net: AddGeometryColumn
http://code.google.com/p/postgis/issues/detail?id=90
Thanks, Kevin.
Not sure if this is the right venue, but I would like to express my thanks
for your
(and everyone else's) work on PostGIS. It's absolutely indispensable for
us; there's
simply no way our project would exist without it.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
