[postgis-devel] Issue 94 in postgis: Rename folders/files to be more consistent
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 9 02:49:10 PST 2009
Status: Accepted
Owner: mark.cav... at siriusit.co.uk
Labels: Milestone-1.4
New issue 94 by mark.cav... at siriusit.co.uk: Rename folders/files to be more
consistent
http://code.google.com/p/postgis/issues/detail?id=94
With the clear split between liblwgeom and the PostgreSQL-specific lwgeom/
directory, it would make sense to rename the lwgeom/ directory to postgis/.
Similarly I'd like to suggest renaming the following files:
lwpostgis.sql -> postgis.sql
liblwpostgis  -> libpostgis-1.4
I think this will make things much clearer. Also by adding in the version
number into the PostgreSQL shared library, it means moving ahead that
developers/users can easily have multiple versions installed which I see as
being very useful in the time ahead.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
