[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 9 04:53:02 PST 2009
Updates:
	Status: Testing
	Owner: robe.... at cityofboston.gov
Comment #3 on issue 95 by robe.... at cityofboston.gov: PostGIS 1.4
http://code.google.com/p/postgis/issues/detail?id=95
Are you sure most.  Most seemed to have the new ST.  Anyrate I fixed the
few I found
that were an issue.  Can you point out others you see that are missing the
ST_?
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
