[postgis-devel] Issue 95 in postgis: PostGIS 1.4 documentation update
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 9 05:05:07 PST 2009
Comment #4 on issue 95 by mark.cav... at siriusit.co.uk: PostGIS 1.4
http://code.google.com/p/postgis/issues/detail?id=95
Okay... maybe most was a little exaggeration! I guess it was just the
sections I was
looking at:
4.1.1
4.1.2
4.3.1
4.4.1
4.6.1
Most of them are GeomFromText() missing the ST_ prefix, which I assume
since we are
moving towards SQL-MM should be the way forward?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
