[postgis-devel] Issue 94 in postgis: Rename folders/files to be more consistent
codesite-noreply at google.com codesite-noreply at google.com
Fri Jan 9 07:25:20 PST 2009
Comment #1 on issue 94 by robe.... at cityofboston.gov: Rename folders/files
http://code.google.com/p/postgis/issues/detail?id=94
I'm okay with renaming to postgis.sql and even renaming the foler.  Would
it be too
much to ask to move the postgis.sql file back to the root where the
spatial_ref_sys.sql is.  It is too much of a brain cramp for me to look for
it
elsewhere :)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
