[postgis-devel] Issue 19
Paul Ramsey pramsey at opengeo.org
Fri Jan 9 12:32:57 PST 2009
http://code.google.com/p/postgis/issues/detail?id=18
Mark, you've upgraded this to 1.4, so we should discuss. Your comment
in the 8.4 block indicates you think we do need to re-check. I'm
pretty sure right now our re-check just testings the float4 boxes
again, so it doesn't accomplish anything. And I'm not sure our
contract with users is to be anything but inexact (but overdetermined)
on index searches.
Now, I think Kevin has some use cases where the float4 round causes
issues. I guess "group by" for points, yes? I think that the use case
of "faster for large geometries" outweighs the use case of "group by
for points", but I could be wrong.
P.
PS - I see the recheck value getting set in the gist_consistent test,
but where does the recheck then occur, if we return true?
Paul Ramsey
OpenGeo - http://opengeo.org
Putting the "Po" in "PostGIS".
