[postgis-devel] Issue 18 in postgis: Remove RECHECK requirement on index
codesite-noreply at google.com codesite-noreply at google.com
Sat Jan 10 22:10:13 PST 2009
Comment #2 on issue 18 by pwramsey3: Remove RECHECK requirement on index
http://code.google.com/p/postgis/issues/detail?id=18
Removed recheck from opclass definition, and from consistent test for 8.4+,
in r3514.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
