[postgis-devel] Memory in the Meantime
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Mon Jan 12 01:29:25 PST 2009
Paul Ramsey wrote:
> I've looked, it's really not a big deal, I'm happy to do it, and I
> want to, since the memory implications for the loader are *massive*
> (fixing the loader requires more than just adding one line, it
> requires a replacement for lwfree_poly which actually does the deep
> free... so, 8 lines :) But still feels wrong to be building what
> should be library infrastructure into the loader.
> I'm going ahead with it, it will allow me to finish up the GUI. Which,
> BTW, feels like a step backwards in code attractiveness, since I
> didn't re-write the core code in the end, just retrofitted the output
> handling.
> P.
Hi Paul,
I've just done a fresh checkout of SVN trunk with this commit and I now
get multiple double-free errors in shp2pgsql on "make check":
loader/Arc.*** glibc detected *** ../loader/shp2pgsql: free(): invalid
pointer: 0x00007fff3b79e290 ***
======= Backtrace: =========
/lib/libc.so.6[0x2b5f6f59b948]
/lib/libc.so.6(cfree+0x76)[0x2b5f6f59da56]
../loader/shp2pgsql[0x4111e2]
../loader/shp2pgsql[0x40b831]
../loader/shp2pgsql[0x40bbf5]
../loader/shp2pgsql[0x40bd0d]
/lib/libc.so.6(__libc_start_main+0xe6)[0x2b5f6f5461a6]
../loader/shp2pgsql[0x4033a9]
======= Memory map: ========
00400000-00433000 r-xp 00000000 fe:05 1057318
/home/pg83/src/postgis-svn/trunk/loader/shp2pgsql
00633000-00634000 rw-p 00033000 fe:05 1057318
00634000-00655000 rw-p 00634000 00:00 0
[heap]
2b5f6f30b000-2b5f6f327000 r-xp 00000000 fe:00 131628
/lib/ld-2.7.so
2b5f6f327000-2b5f6f32e000 rw-p 2b5f6f327000 00:00 0
2b5f6f526000-2b5f6f528000 rw-p 0001b000 fe:00 131628
/lib/ld-2.7.so
2b5f6f528000-2b5f6f672000 r-xp 00000000 fe:00 131625
/lib/libc-2.7.so
2b5f6f672000-2b5f6f871000 ---p 0014a000 fe:00 131625
/lib/libc-2.7.so
2b5f6f871000-2b5f6f874000 r--p 00149000 fe:00 131625
/lib/libc-2.7.so
2b5f6f874000-2b5f6f876000 rw-p 0014c000 fe:00 131625
/lib/libc-2.7.so
2b5f6f876000-2b5f6f87b000 rw-p 2b5f6f876000 00:00 0
2b5f6f87b000-2b5f6f8fd000 r-xp 00000000 fe:00 131624
/lib/libm-2.7.so
2b5f6f8fd000-2b5f6fafc000 ---p 00082000 fe:00 131624
/lib/libm-2.7.so
2b5f6fafc000-2b5f6fafe000 rw-p 00081000 fe:00 131624
/lib/libm-2.7.so
2b5f6fafe000-2b5f6fb00000 rw-p 2b5f6fafe000 00:00 0
2b5f6fb00000-2b5f6fb16000 r-xp 00000000 fe:00 131609
/lib/libgcc_s.so.1
2b5f6fb16000-2b5f6fd16000 ---p 00016000 fe:00 131609
/lib/libgcc_s.so.1
2b5f6fd16000-2b5f6fd17000 rw-p 00016000 fe:00 131609
/lib/libgcc_s.so.1
2b5f70000000-2b5f70021000 rw-p 2b5f70000000 00:00 0
2b5f70021000-2b5f74000000 ---p 2b5f70021000 00:00 0
7fff3b78a000-7fff3b79f000 rw-p 7ffffffea000 00:00 0
[stack]
7fff3b7ff000-7fff3b800000 r-xp 7fff3b7ff000 00:00 0
[vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0
[vsyscall]
./run_test: line 153: 7366 Aborted ${SHP2PGSQL}
${TEST}.shp $_tblname > ${TMPDIR}/loader 2> ${TMPDIR}/loader.err
failed (running shp2pgsql: /tmp/pgis_reg_6744/loader.err)
loader/ArcM.*** glibc detected *** ../loader/shp2pgsql: double free or
corruption (out): 0x00007fff9fd90880 ***
/lib/libc.so.6[0x2b6a0afa9948]
/lib/libc.so.6(cfree+0x76)[0x2b6a0afaba56]
/lib/libc.so.6(__libc_start_main+0xe6)[0x2b6a0af541a6]
[heap]
2b6a0ad19000-2b6a0ad35000 r-xp 00000000 fe:00 131628
/lib/ld-2.7.so
2b6a0ad35000-2b6a0ad3c000 rw-p 2b6a0ad35000 00:00 0
2b6a0af34000-2b6a0af36000 rw-p 0001b000 fe:00 131628
/lib/ld-2.7.so
2b6a0af36000-2b6a0b080000 r-xp 00000000 fe:00 131625
/lib/libc-2.7.so
2b6a0b080000-2b6a0b27f000 ---p 0014a000 fe:00 131625
/lib/libc-2.7.so
2b6a0b27f000-2b6a0b282000 r--p 00149000 fe:00 131625
/lib/libc-2.7.so
2b6a0b282000-2b6a0b284000 rw-p 0014c000 fe:00 131625
/lib/libc-2.7.so
2b6a0b284000-2b6a0b289000 rw-p 2b6a0b284000 00:00 0
2b6a0b289000-2b6a0b30b000 r-xp 00000000 fe:00 131624
/lib/libm-2.7.so
2b6a0b30b000-2b6a0b50a000 ---p 00082000 fe:00 131624
/lib/libm-2../run_test: line 153: 7372 Aborted
${SHP2PGSQL} ${TEST}.shp $_tblname > ${TMPDIR}/loader 2>
loader/ArcZ.*** glibc detected *** ../loader/shp2pgsql: double free or
corruption (out): 0x00007ffffade08d0 ***
/lib/libc.so.6[0x2affaff57948]
/lib/libc.so.6(cfree+0x76)[0x2affaff59a56]
/lib/libc.so.6(__libc_start_main+0xe6)[0x2affaff021a6]
[heap]
2affafcc7000-2affafce3000 r-xp 00000000 fe:00 131628
/lib/ld-2.7.so
2affafce3000-2affafcea000 rw-p 2affafce3000 00:00 0
2affafee2000-2affafee4000 rw-p 0001b000 fe:00 131628
/lib/ld-2.7.so
2affafee4000-2affb002e000 r-xp 00000000 fe:00 131625
/lib/libc-2.7.so
2affb002e000-2affb022d000 ---p 0014a000 fe:00 131625
/lib/libc-2.7.so
2affb022d000-2affb0230000 r--p 00149000 fe:00 131625
/lib/libc-2.7.so
2affb0230000-2affb0232000 rw-p 0014c000 fe:00 131625
/lib/libc-2.7.so
2affb0232000-2affb0237000 rw-p 2affb0232000 00:00 0
2affb0237000-2affb02b9000 r-xp 00000000 fe:00 131624
/lib/libm-2.7.so
2affb02b9000-2affb04b8000 ---p 00082000 fe:00 131624
/lib/libm-2.7.so
2affb04b8000-2affb04ba000 rw-p 00081000 fe:00 131624
/lib/libm-2.7.so
2affb04ba000-2affb04bc000 rw-p 2affb04ba000 00:00 0
2affb04bc000-2affb04d2000 r-xp 00000000 fe:00 131609
/lib/libgcc_s.so.1
2affb04d2000-2affb06d2000 ---p 00016000 fe:00 131609
/lib/libgcc_s.so.1
2affb06d2000-2affb06d3000 rw-p 00016000 fe:00 131609
/lib/libgcc_s.so.1
2affb4000000-2affb4021000 rw-p 2affb4000000 00:00 0
2affb4021000-2affb8000000 ---p 2affb4021000 00:00 0
7ffffadcd000-7ffffade2000 rw-p 7ffffffea000 00:00 0
[stack]
7ffffadfe000-7ffffadff000 r-xp 7ffffadfe000 00:00 0
[vdso]
[vsyscall]
./run_test: line 153: 7378 Aborted ${SHP2PGSQL}
loader/Polygon.*** glibc detected *** ../loader/shp2pgsql: double free
or corruption (out): 0x00007ffff3c63740 ***
Any chance you could take a look?
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
