[postgis-devel] Issue 18 in postgis: Remove RECHECK requirement on index
codesite-noreply at google.com codesite-noreply at google.com
Mon Jan 12 03:36:42 PST 2009
Comment #4 on issue 18 by mark.cav... at siriusit.co.uk: Remove RECHECK
http://code.google.com/p/postgis/issues/detail?id=18
Excellent. One of things I've been thinking is that with this change (and
also
potential alignment changes after 1.4), how do we benchmark this to show it
actually
is an improvement? At the moment, I don't think there is anything in the
regression
tests to do this...
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
