[postgis-devel] Issue 94 in postgis: Rename folders/files to be more consistent
codesite-noreply at google.com codesite-noreply at google.com
Mon Jan 12 03:54:44 PST 2009
Comment #4 on issue 94 by robe.... at cityofboston.gov: Rename folders/files
http://code.google.com/p/postgis/issues/detail?id=94
Mark,
The answer to your question about spatial_ref_sys.sql is NO.
The reason I feel that way is if I'm doing a hard dump reload -- I have a
lot of
custom records in my spatial_ref_sys and I may not care to load the ones
you have or
I may want a partial set to save space.  This is not true with the
functions.  I
always want all of those :).  Call me selfish :)---.
I'm all for going hog wild on stamping 1.4.  1.4 will be a big change and
it would be
really nice if I can run both simultaneously on the same PostgreSQL service
and then
slowly port over at my leisure.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
